ArcGIS diagrammer 10.1 problems after installation - cannot run program
2700
11-20-2012 03:42 PM
RowenaDanks
I am having trouble with ArcGIS Diagrammer 10.1 because I get an error message [Microsoft.NET Framework] after the wizard states it was a sucessful installation about an 'Unexpected exception has occured in your application......the type initialzer for ESRI.ArcGIS.Diagrammer.DiagrammerEnvironment threw an exception' I have an option to continue or quit but the continue does not work for me.  The diagrammer window is blank. Cheers jo
RowenaDanks
i have worked out that ArcGIS diagrammer did not like being installed onto a Solid State drive and that it works Ok being installed onto the external hard drive (that is formatted as a normal C:\)
WhereMatters
I am having the same problem. Only that i am not using a solid state drive, I am using a normal hard drive and installed it to c:\
