Arcgis 10.2.1 Slow editing features
1229
01-20-2014 09:43 PM
PhilipHughes
Have upgraded to 10.2.1 and am suffering very slow performance when trying to update entries with a raster footprint.
database is an SQL 2012,  sde 10.1
Using sde geodatabase with direct connection and database authentication.
Open the feature class,  start editing,  then try and enter data into a field and step to the next record using arrow key,  this takes a long time (10 - 15 seconds).  When editing the same feature locally on the server it is instant.  It is also instant when editing from a workstation running 10.1
Have removed profile from appdata,  same problem.
Have tried operating system authentication for the database connection again same problem.
The feature has around 6000 records in total.
anusuyamedhi
have you installed latest service pack ?
Geodatabase has to be upgraded to the latest service pack or patch for its release
thanks
PhilipHughes
SDE is at the latest patch, however database is not updated as identified by arccatalog but it says database is at current version.  I have various clients still on ArcGIS 10.1 and 10.2 that have not such speed issue.
