APDM and ESRI Telecom Model
2780
11-14-2011 03:03 AM
AlexandreRoba
Dear all,
We currently have our entire Pipeline network defined in an APDM templated geodatabase. This geodatabase is used to support a well defined set of processes (Right of way, Public utility declaration...) We are now requested to support also our Optical fiber network on the same processes. We are given the following options:
1) we could polute our APDM geodatabase with data wich are not pipe. After all a duct and a pipeline could end up both as Station series and a line loop with a discriminant. This would allow us to reuse the same code. We mainly need to support online and off line feature.
2) build a separate geodatabase based on the ESRI Telecom Data model for example and try to build the same processes on this one... Well not that easy has they are really different.
Has anyone gone through this process? What option did you toke?
Thanks for any help.
Regards,
Alexandre
Dr_T_R_NisarAhamed
Dear all:
Is there any way to access sample pipeline data adopting APDM model?
Best regards
Ahamed
Cristian_Galindo
Hi!! Have you success in this effort?
I'm looking for something simmilar due my master. Have you implemented APDM? I have several questions
