Any Versioning tutorials?
1976
04-26-2011 06:42 AM
RandellMcGlynn
Hello, I'm trying to wrap my head around versioning with SDE are there any good tutorials dealing with ArcSDE in version 10?
Thanks.
DerekLaw
Esri Esteemed Contributor
Hi Randell,
I'm not aware of any specific tutorials on versioning, but these resources are a good place to start:
  1. Geodatabase Essentials Part 2 - An Introduction to ArcSDE Geodatabases video
  2. Versioning 101 - ArcUser technical article
Hope this helps,
RandellMcGlynn
Yes it does help thank you.
KenGalliher
The web help is great place to start.  Here's the first page, just work your way down.
http://help.arcgis.com/en/arcgisserver/10.0/help/arcgis_server_dotnet_help/index.html#/What_is_a_ver...
If you have access to an ArcSDE geodatabase and the ability to view the system tables (i.e. Sql Server Mgmt. Studio, Sql Developer) you can create some data, create versions, edit, reconcile, post and then look at what the tables are doing.  It's a good way to understand the back-end processes which can translate into better version management.
Also, check out the geodatabase blog...
http://blogs.esri.com/Dev/blogs/geodatabase/archive/tags/Versioning/default.aspx
RandellMcGlynn
Beautiful! Thank you all very much.
