Applied SP# to ArcSDE 10 and received the following message:
The Service Pack (ArcSDE 10.0 Service Pack 3) has been successfully applied to ArcSDE 10.0 Server.
While trying to start ArcSDE 10, received the following message:
sdemon -o start -u sde -p ????
ArcSDE 10.0 for Oracle11g Build 1937 Tue Aug 16 16:08:18 2011
ST_Geometry Schema Owner: (SDE) Type Release: 1007
Instance initialized for ((sde)) . . .
Connected to instance . . .
ERROR in checking system st_geometry type (1).
Error checking the existence of system tables. Run
the Upgrade Geodatabase tool to install/upgrade system tables (-450).
Refer ArcSDE installation guide for instructions.
Could not start ArcSDE -- Check Network, $SDEHOME disk, DBMS settings and dbinit.sde.
The Network is fine.
$SDEHOME disk (?)
DBMS settings are good.
dbinit.sde is empty.
I'm a DBA by trade and new to GIS/ESRI technologies. I would appreciate any advice given.
Thanks in advance.
