Address Coder 10 and Zip Code Latitude/Longitude
1159
02-01-2012 06:45 AM
GrantMullins
Has anyone else had a problem with Address Coder matching at the Zip level but not assigning the Lat/Long?  My records that matched at the zip code level show up in the attribute table as 100% zip matches but get no geometry.  I'm running 10.0 SP 3 ArcGIS Desktop with BA Desktop SP 2.  I've also applied the Geocoding patch for SP 3.
Jason_RobinsonRobinson
Grant,
In Address Coder go to File>Options and then the Geocoding tab.  In the bottom section which is Minimum Tolerance for Centroids select the Match at any Level.  This will provide lat/longs for records geocoded at the zip code level in AC10.
Regards,
Jason R.
