Adding field to Versioned Enterprise Geodatabase
7397
02-19-2015 12:06 PM
Lebowski
I have run into some problems in the past and I just want to verify the steps to properly 'unversion' my Enterprise Geodatabase in order to add a new field in multiple feature classes:
1. Reconcile all versions
2. Delete versions except for the default
3. Unversion database
Could someone please verify these are the necessary steps so I can avoid any complications?
Chad
Robert_LeClair
Esri Esteemed Contributor
Chad - the data owner of a versioned feature class can add a new field without going through the whole process of unregistering and re-registering.  Once the data owner creates the new field, it is seen in all versions.
Regards,
Robert LeClair
Esri-Denver
Robert_LeClair
Regards,
Robert LeClair
Esri-Denver
chadh
I have found that not to be true. I have done that before and it "ruins" the whole database
Robert_LeClair
By "ruins" the whole database, what do you mean?  Since there's only 1 feature class (that is versioned), adding an attribute field would be seen across all versions.
