Adding a county to an existing shapefile
1376
06-18-2014 08:47 AM
JenRamos
Very basic question as it's been years since I used ArcView.
I need to add a county to an existing shapefile.  What is the easiest way to do so?
IanMurray
Honored Contributor
Use the Append Tool if you want to add it to the existing shapefile
If you want to make a new shapefile from the two, use the Merge Tool.
Zeke
Honored Contributor
Is the county in a shapefile? If the files are in the same format, you could use Append, or copy/paste.
TimWitt
You can start an editing session and then add it through that.
If you have a different shapefile that has the county you want to add already, you can use the append or merge tool.
I hope this helps!
