Add Field to Table
1771
08-27-2012 12:48 PM
JennWhite
Hello All,
I'm currently using ArcMap 10.1.
Is anyone having an issue with batching a new field to their tables? When I add a new field by using the batch tool of "Add field", it doesn't show up after refreshing, or closing and re-opening the table. What I need to do is shut down my session an open a new session.
I'm curious to know if there's anyone else out there with this problem.
Cheers!
JuanLuera
Hola Jenn,
I just tested this within 10.1 with about 4 or 5 layers, using two different scenarios and the batch option for the �??Add Field�?� tool worked without any issues. If you are current with your maintenance and want to submit an incident with us, I would be happy to work with you on this issue. Gracias, Jenn!
Support Service
1-888-377-4575
http://support.esri.com/en/webform/s...275/chat/false
