A script referencing sde.gdb_items_vw gives ORA-00942: table or view does not exist
3422
03-22-2013 06:29 AM
TimLangner
Hi there
I am trying to locate which fields domains are being used by. I am using ArcMap 10.1 but accessing a 9.3.1 geodatabase stored in an Oracle 10.2g database,
There was a a script on the following page:
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//006z000000t9000000
However when ever I run it I get the error:
00942. 00000 -  "table or view does not exist"
It is for the table sde.gdb_items_vw which does not exist. Would anyone happen to know why it might not exist?
I am trying to delete a domain but before I can do so, I need to remove it from a field but I need to see which field(s) are still referencing it.
Kind regards
Tim
VinceAngelo
Esri Esteemed Contributor
That script assumes 10.x geodatabase; 9.3.1 doesn't have the same organization.
- V
TimLangner
Thanks for pointing that out Vangelo.
Is their a list of tables used in 9.3.1 or even a comparison chart which shows the table name differences between version side by side?
Kind regards
Tim
VinceAngelo
The geodatabase table structures are documented in each release.  The changes
at 10.0 were highlighted in "What's New" pages and multiple other forms during
10.0 rollout.  There is no table comparison between 9.x and 10.x though, since
the strucutre is so radically different (the relationships are now stored in XML).
- V
TimLangner
Thank you for that. I will look through the What's new sections.
