9.3 vs 10.1 Yields Different Results
1660
01-29-2013 07:01 AM
RogerLivingston
Why does the 10.1 geocoder yield different results on the same dataset?
All of the geocoding parameters are the same, the only difference I see is that the Standardized Address checkbox is greyed out in the 10.1 Geocoder.  I have created several geocoders including single address and general address all with the same results.
Here is a specific example:
These addresses were matched in 9.3 but were unmatched in 10.1
Input Address_____________ Matching Address___________Score
10382 SW KENNEDY ST______10380 SW KENNEDY ST______64
10618 NW MALIA LN_________10617 NW MALIA LN________64
10918 SW CELESTE LN_______10910 SW CELESTE LN______64
[ATTACH=CONFIG]21162[/ATTACH]
[ATTACH=CONFIG]21163[/ATTACH]
Any ideas?
BradNiemand
This thread should answer your question:
http://forums.arcgis.com/threads/61960-Geocoding-10-vs-10.1
Brad
by Anonymous User
Not applicable
Original User: woobers
I am running 10.1 SP1, which according to the 10 vs 10.1 thread was going to address the issue w/10.1 geocoding.  Did it get fixed in 10.1 SP1 or not?
BradNiemand
There is really no bug to fix, it is a default feature.  By default, searching without zones is not turned on.  If you open the locator properties dialog and go to the "Geocoding options" section, just change the "Match with no zones" property to "Yes".  This should solve your problem.
Brad
