10.2 attribute tables are not opening
5311
01-13-2015 08:52 AM
ChristopherBride
I am trying to open attribute tables in an .mxd created in 10.0 and none of the attribute tables are opening for old or new data. I created a new .mxd and have the same problem. Obviously this is a rather huge issue. I've played with field formatting to no avail.
ChristopherBride
dumbass, did you look on your other monitor?
ChristopherBride
DanPatterson_Retired
I took the liberty of marking your answer as correct since you took the time to report the oft forgotten solution.  Kudos...
ChristopherBride
I had just gotten a new 2nd monitor to pair with my laptop. When I upgraded to 10.2 it had gotten a little lost!
PeterJones
You are not the first and you won't be the last who will be "confused" by this. I have the luxury of being allowed to remotely login into another computer, which is across two screens, but on my computer I can only see it on one screen ... so that is really fun trying to get things of the second screen!
