10.1 Geodatabase Issues
1974
09-03-2012 10:47 AM
MattLayman
I recently upgraded to ArcGIS 10.1, and am having issues creating new feature classes in my geodatabases.  In addition, I can't
edit data within the geodatabase.  I get an error message when I start an edit session that says I do not have "appropriate permissions".  I never had this problem in ArcGIS 10.
JoeBorgione
Is this a file geodatabase, personal geodatabase or is it served through SDE?  If the latter, I suspect your user permissions have been changed due to the upgrade, assuming you upgraded Server/SDE as well.  Not sure what to tell you if its a file or personal geodatabase...
That should just about do it....
