10.1 Geocode Service Issues
842
09-18-2012 07:02 AM
BrianLeroux
Is anyone else trying to use a geocode service in 10.1? Are you having any issues? I currently have 3 issues.
1) Batch Geocoding wioth a composite locator only uses one of the locators unless using a single line input.
2) When batch goecoding over 2000 records your ID numbers must start at 1. If you start at 0 the resulting IDs do not match. Less than 2000 you can use 0 or 1 and it doesn't matter
3) Reversegeocoding does not work. Using the same input as the Reverse Geocode API sample I get a message that the query inputs are incorrect. It looks like the API reference for reverse geocoding did not change from 10.0 to 10.1. Did the parameter input format change?
I'd be curious to see if anyone else is having similar issues.
