arcSDE9.3.1 repository upgrade to arcSDE10.1 failed
526
09-18-2012 07:22 AM
SunilKelkar
We have arcSDE9.3.1 in Oracle11g 64 bit. We are attempting to upgrade arcSDE9.3.1 to 10.1 using ArcMAP's upgrade geodatabase tool and attempt is failing with following errors.
Finished checking prerequisites.
Server tables and stored procedures are up to date.
The geodatabase system table could not be created. [ORA-00942: table or view does not exist
] [GDB_Items : Error (-218)]
The geodatabase system table could not be created. [GDB_Items : Error (-218)]
Unpaused the database.
Failed to execute (UpgradeGDB).
any ideas
VinceAngelo
Esri Esteemed Contributor
The -218 error is SE_TABLE_REGISTERED, with a description "Table already registered".
Have you attempted an upgrade and had it fail?  Did you create a GDB_ITEMS table
on your own?  Is there a table named GDB_ITEMS owned by user SDE?
Did you make a complete (and verified) backup of the SDE user tables before attempting
upgrade?
- V
SunilKelkar
There is no GDB_ITEMS table in SDE schema. How do I create them? I thought this table is created as a part of upgrade.
VinceAngelo
There *shouldn't* be such a table until after an upgrade.  Is a reference to GDB_Items
present in the ArcSDE table registry?  Did someone attempt and clean up after a
failed database upgrade?
Tracking down exotic upgrade problems is more in the realm of Tech Support than
these Forums.
- V
SunilKelkar
TABLE_REGISTRY as well as COLUMN_REGISTRY does not have any reference of the GDB_ITEMS table.
If this table is a part of ***Upgrade*** then why it is failing on "Table does not exists"?
OK, I will open a trouble ticket with ESRI Support.
