10.1 | Calculate Statistics against Raster Dataset in a Raster Catalog
1057
09-11-2013 04:59 AM
BrandonRana
I am attempting to calculate statistics using the tool in the toolbox in ArcMap 10.1 Standard.  When selecting the input dataset, I want to select a raster dataset that is in a raster catalog.  All of this is within a database connection to our SDE server.  However, only raster datasets in the root of the SDE connection are available to select.  The catalogs are not listed, therefore I can't drill down into them to access the underlying raster datasets.  Is this normal behavior?  I don't remember this from 10.0.
By the way, this will work in a python script.
Brandon
