0509-150   Dependent module libskgxp11.so could not be loaded
5546
11-26-2013 08:19 PM
EmadAl-Mousa
Error faced while starting up ArcSDE:
Enter password:
exec(): 0509-036 Cannot load program oracleoradbd because of the following errors:
0509-150 Dependent module libskgxp11.so could not be loaded.
0509-022 Cannot load module libskgxp11.so.
0509-026 System error: A file or directory in the path name does not exist.
ERROR:
ORA-12547: TNS:lost contact
My Current Environment:
Oracle11gR2 (11.2.0.3.8)
ArcSDE 10.0
Server: IBM AIX
I had this error while cloning the oracle database from one server to another.
EmadAl-Mousa
The solution is the following:
*.* Sticky Bit permission *.* and Relinking the libararies
chmod 6751 $ORACLE_HOME/bin
ls â??l oracle
also,
chmod 6751 $ORACLE_HOME/lib
Then, use the unix command:
relink all
then i tried starting ArcSDE and it works fine.
Also, make sure while you are in the server using "sde" unix user account to try "sqlplus" and enter your "sde" user account and password....it should work fine.
EmadAl-Mousa
ls â??l oracle
also,
relink all
