Geoprocessing tool to report long description of layer
971
12-14-2016 07:16 PM
Status: Open
MarkChilcott
sdelayer -o describe_long : Gives information on a layer such as the current spatial index, the layerID, system units etc that cannot be found through ArcCatalog.  Create a tool that returns all the information about a layer, so you don't have to go looking in the SDE user system tables.
ArcSDE 10.2
Layer    Administration Utility
Layer Description ....: <None>
Table Owner ..........: CUSTODIANS_AGENCY
Table Name ...........: OVG_VISTAS_REVAL
Spatial Column .......: SHAPE
Layer Id .............: 2237
SRID .................: 2
Auth SRID.............: 3857
Minimum Shape Id .....: 1
Offset ...............:
  falsex:  -20037700.000000
  falsey:  -30241100.000000
System Units .........:      10000.000000
Z Offset..............:          0.000000
Z Units ..............:          1.000000
Measure Offset .......: <None>
Measure Units ........: <None>
XY Cluster Tolerance .:          0.001
Spatial Index ........:
  parameter:    SPIDX_GRID,GRID0=4000,FULL
  exist:        Yes
  array form:   4000,0,0
Layer Envelope .......:
  minx:  16011558.40080,        miny:  -5349578.14150
  maxx:  16528928.07960,        maxy:  -4751324.92700
Entities .............: nac+
Layer Type ...........: Extended SQL Type/ST_GEOMETRY
Creation Date ........: 08/11/16 10:45:08
I/O Mode .............: NORMAL
Autolocking ..........: Enabled
Precision.............: High
User Privileges ......: SELECT, UPDATE, INSERT, DELETE
Coordinate System ....: PROJCS["WGS_1984_Web_Mercator_Auxil
174532925199433]],PROJECTION["Mercator_Auxiliary_Sphere"],P
R["Auxiliary_Sphere_Type",0.0],UNIT["Meter",1.0]]
Layer Configuration ..: DEFAULTS
1 Comment
AlexRodd
