Geodatabase on Azure SQL Managed Instance
2169
02-09-2023 11:35 AM
Status: Open
fordint
The alias for Azure SQL Managed Instance is not working. Suppose, we have an alias i.e. GISDBAZ that points to abc-xyz.database.windows.net on SQL Managed Instance and we hope we can use the alias the same way as if the alias points to a physical computer or virtual machine.
We do not want to use [email protected] and password; we want to use operating system authentication;
We tried [email protected] and password even in SQL server management studio, when the alias is used, operating system authentication is not working, and according to Microsoft, this is currently a limitation of managed instance.
3 Comments
MarceloMarques
ArcGIS does not support the alias with Azure SQL at present, but Esri is looking at testing this again to see what needs to happen in order for ArcGIS to support it.
fordint
Is there a timeline for when it will be implemented?
MarceloMarques
No there isn't one yet. If this idea gest enough kudos, then it can shorten the wait time. The customer can also log a support ticket with Esri Technical Support and request an enhancement request to be created, that also helps to shorten the time the new functionality gets implemented.
