Bring DBTUNE Template File Back
3321
05-02-2020 06:31 PM
Status: Open
MarceloMarques
I am a database administrator responsible to setup enterprise geodatabases that store very large datasets (terabytes), the best practice is to separate tables and indexes to improve performance, this reduces database datafiles fragmentation and contention, thus database i/o improves which leads to better performance, also improves maintenance tasks such as sde compress (versioning), rebuilding indexes and gather new statistics. In order to accomplish this I use a custom DBTUNE file.
1) DBTUNE documentation
If you look the 10.2.2 documentation for PostgreSQL it has an example on how to configure a custom dbtune keyword.
B_STORAGE              "TABLESPACE userdata"
B_INDEX_ROWID          "WITH (FILLFACTOR = 60)TABLESPACE userdata"
B_INDEX_USER          "WITH (FILLFACTOR = 75)TABLESPACE userdata"
BLK_STORAGE                "TABLESPACE rasterdata"
BLK_INDEX_COMPOSITE        "WITH (FILLFACTOR = 90)USING INDEX TABLESPACE"
A_INDEX_RASTER             "WITH (FILLFACTOR = 75) TABLESPACE rasterdata"
B_INDEX_RASTER             "WITH (FILLFACTOR = 75) TABLESPACE rasterdata"
BND_STORAGE                "TABLESPACE rasterdata"
BND_INDEX_COMPOSITE        "WITH (FILLFACTOR = 90)USING INDEX TABLESPACE"
RAS_STORAGE            "TABLESPACE rasterdata"
RAS_INDEX_ID           "WITH (FILLFACTOR = 90)USING INDEX TABLESPACE rasterdata"
Notice that for some keywords we have to use the " USING INDEX" syntax spite of the keyword name to have the word "INDEX", this because the dbtune keyword is used to create a table and an index as well.
10.2.2 was the last release of the ArcSDE Binaries Installer.
2) DBTUNE template file
After the "ArcSDE_for_PostgreSQL_on_Windows_1022_140610.exe" was installed we had a full dbtune template that we could use to fill up with the tablespaces name .
3) Remarks
It seems that this knowledge was dropped in the more recent versions of the documentation.
If possible consider to add this important info about the dbtune keywords back into the documentation (Oracle, SQL Server, PostgreSQL) and continue to provide a dbtune template file going forward, a good place to find it would be in the ArcGIS installation under the Database Support folder.
5 Comments
George_Thompson
Here is a way to do it, supported: Alter configuration keywords—Geodatabases in PostgreSQL | Documentation
Is that what you are looking for?
BillFox
Have not heard that term in a long time.
Is your environment virtual and on SAN gear?
MarceloMarques
I am a very experienced Geodatabase Administrator that has been using DBTUNE for over 20 years, this idea is to bring that forgotten knowledge back into the current documentation and to continue to provide a dbtune template file that is so useful for the geodatabase administrators. I talk more about this here "Mapping & Charting Solutions (MCS) Enterprise Databases Best Practices".
MarceloMarques
The best practice to separate tables and indexes applies for virtual and SAN storages. I talk more about this in my best practices guides books, check it out Mapping & Charting Solutions (MCS) Enterprise Databases Best Practices.
In particular this might be of interest DBTUNE configuration keywords and disk configuration.
George_Thompson
Ah ok, I see. I can understand that and appreciate the clarification. I can say that many people tried to toy with the file and created some interesting problems along the way.
