GDBAdminPython2016.zip
5909
03-09-2016 08:35 AM
This folder contains the demos and slides from the Administering your Enterprise Geodatabase using Python tech session at Esri Developer Summit 2016
Comments
George_Thompson
Esri Notable Contributor
Adding a few other groups....... Thanks for those tools and slides!
Managing DataEnterprise GIS
Lake_Worth_BeachAdmin
What is the difference when running Analyze Data and Rebuilding indexes with the parameters (NO_SYSTEM/SYSTEM). SHould I run it both like the video??? I get an error when I try to run NO_SYSTEM.
George_Thompson
I
include_system
Indicates whether statistics will be gathered on the states and state lineages tables.
You must be the geodatabase administrator for this option to be activated.
This option only applies to geodatabases. If the input workspace is a database, this option will be ignored.
  • NO_SYSTEM —Statistics will not be gathered on the states and state lineages tables. This is the default.
  • SYSTEM —Statistics will be gathered on the states and state lineages tables.
Analyze Datasets—Help | ArcGIS Desktop  here is the help documentation on the tool.
Verify that you are using the correct user connection (SDE) for the SYSTEM tables and the DATA owner for the other tables.
Well I get tons of errors when I run thi script but my own script runs fine. I use SYSTEM but your demo vids the lady used SYSTEM first and then ran it again with NO_SYSTEM. had me curious.
Version history
Last update:
‎03-09-2016 08:35 AM
Updated by:
Contributors
