In response to https://community.esri.com/migration-blogpost/54807
which adds some bling and zing to your SDE database, I've gotten a few comments regarding doing the same type of tuning with the Geography Storage type. Easy Cheesy, just note that this alteration simply replaces geometry with geography, and removes the bounding box from the index creation. Happy tuning!
--ORIGINAL SQL CODE FROM --http://stackoverflow.com/users/2250424/greengeo --MODIFIFIED TO INCLUDE SPATIAL INDEX HELP OUTPUT --IN TABLE --!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! --LOOK FOR THE EXCLAMATION POINTS IN THIS CODE --THERE ARE SEVERAL USER-SUPPLIED VARIABLES THAT MUST --BE INPUT FOR THIS SP TO WORK --!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! USE [GPS_COLLAR] GO ALTER PROCEDURE dbo.sp_tune_spatial_index ( @tabnm VARCHAR(MAX), -- This parameter stores the name of the spatial table for which you are tuning the index @idxnm VARCHAR(MAX), -- This parameter stores the name of the spatial index of the named table @min_cells_per_obj INT, -- Minimum Cells Per Object to test on. Suggested to start at 2. @max_cells_per_obj INT, -- Maximum Cells Per Object to test on. /* The test requires two geography instances to use in test query 1 and 2. The first one should cover the area of default extent. The second should cover an area roughly the size of the area shown when zoomed in, panning around. It is required that the variable store a string that will create the geography instance since this will be done within the procedure and cannot be a variable of type: GEOGRAPHY. The SRID of these instances must match that of the table you are testing. */ @testgeom1 VARCHAR(MAX), -- This parameter stores the first geography instance creation string that will be used in the test @testgeom2 VARCHAR(MAX) -- This parameter stores the second geography instance creation string that will be used in the test ) AS SET NOCOUNT ON; /* Prior to running this procedure, two tables are required. These tables are created here to prepare for running the procedure. */ PRINT 'Checking for required tables...' IF EXISTS(SELECT 1 FROM sysobjects WHERE name IN ('cell_opt_perm', 'spat_idx_test_result')) BEGIN PRINT '... The "cell_opt_perm" and "spat_idx_test_result" tables exist.' END ELSE BEGIN PRINT '... Creating "cell_opt_perm" and "spat_idx_test_result" tables.' CREATE TABLE cell_opt_perm( [perm_id] [smallint] NOT NULL, [permutation] [nvarchar](4) NOT NULL, [level1] [nvarchar](6) NOT NULL, [level2] [nvarchar](6) NOT NULL, [level3] [nvarchar](6) NOT NULL, [level4] [nvarchar](6) NOT NULL ) INSERT INTO cell_opt_perm ([perm_id], [permutation], [level1], [level2], [level3], [level4]) VALUES (1,'LLLL','LOW','LOW','LOW','LOW'), (2,'LLLM','LOW','LOW','LOW','MEDIUM'), (3,'LLLH','LOW','LOW','LOW','HIGH'), (4,'LLML','LOW','LOW','MEDIUM','LOW'), (5,'LLMM','LOW','LOW','MEDIUM','MEDIUM'), (6,'LLMH','LOW','LOW','MEDIUM','HIGH'), (7,'LLHL','LOW','LOW','HIGH','LOW'), (8,'LLHM','LOW','LOW','HIGH','MEDIUM'), (9,'LLHH','LOW','LOW','HIGH','HIGH'), (10,'LMLL','LOW','MEDIUM','LOW','LOW'), (11,'LMLM','LOW','MEDIUM','LOW','MEDIUM'), (12,'LMLH','LOW','MEDIUM','LOW','HIGH'), (13,'LMML','LOW','MEDIUM','MEDIUM','LOW'), (14,'LMMM','LOW','MEDIUM','MEDIUM','MEDIUM'), (15,'LMMH','LOW','MEDIUM','MEDIUM','HIGH'), (16,'LMHL','LOW','MEDIUM','HIGH','LOW'), (17,'LMHM','LOW','MEDIUM','HIGH','MEDIUM'), (18,'LMHH','LOW','MEDIUM','HIGH','HIGH'), (19,'LHLL','LOW','HIGH','LOW','LOW'), (20,'LHLM','LOW','HIGH','LOW','MEDIUM'), (21,'LHLH','LOW','HIGH','LOW','HIGH'), (22,'LHML','LOW','HIGH','MEDIUM','LOW'), (23,'LHMM','LOW','HIGH','MEDIUM','MEDIUM'), (24,'LHMH','LOW','HIGH','MEDIUM','HIGH'), (25,'LHHL','LOW','HIGH','HIGH','LOW'), (26,'LHHM','LOW','HIGH','HIGH','MEDIUM'), (27,'LHHH','LOW','HIGH','HIGH','HIGH'), (28,'MLLL','MEDIUM','LOW','LOW','LOW'), (29,'MLLM','MEDIUM','LOW','LOW','MEDIUM'), (30,'MLLH','MEDIUM','LOW','LOW','HIGH'), (31,'MLML','MEDIUM','LOW','MEDIUM','LOW'), (32,'MLMM','MEDIUM','LOW','MEDIUM','MEDIUM'), (33,'MLMH','MEDIUM','LOW','MEDIUM','HIGH'), (34,'MLHL','MEDIUM','LOW','HIGH','LOW'), (35,'MLHM','MEDIUM','LOW','HIGH','MEDIUM'), (36,'MLHH','MEDIUM','LOW','HIGH','HIGH'), (37,'MMLL','MEDIUM','MEDIUM','LOW','LOW'), (38,'MMLM','MEDIUM','MEDIUM','LOW','MEDIUM'), (39,'MMLH','MEDIUM','MEDIUM','LOW','HIGH'), (40,'MMML','MEDIUM','MEDIUM','MEDIUM','LOW'), (41,'MMMM','MEDIUM','MEDIUM','MEDIUM','MEDIUM'), (42,'MMMH','MEDIUM','MEDIUM','MEDIUM','HIGH'), (43,'MMHL','MEDIUM','MEDIUM','HIGH','LOW'), (44,'MMHM','MEDIUM','MEDIUM','HIGH','MEDIUM'), (45,'MMHH','MEDIUM','MEDIUM','HIGH','HIGH'), (46,'MHLL','MEDIUM','HIGH','LOW','LOW'), (47,'MHLM','MEDIUM','HIGH','LOW','MEDIUM'), (48,'MHLH','MEDIUM','HIGH','LOW','HIGH'), (49,'MHML','MEDIUM','HIGH','MEDIUM','LOW'), (50,'MHMM','MEDIUM','HIGH','MEDIUM','MEDIUM'), (51,'MHMH','MEDIUM','HIGH','MEDIUM','HIGH'), (52,'MHHL','MEDIUM','HIGH','HIGH','LOW'), (53,'MHHM','MEDIUM','HIGH','HIGH','MEDIUM'), (54,'MHHH','MEDIUM','HIGH','HIGH','HIGH'), (55,'HLLL','HIGH','LOW','LOW','LOW'), (56,'HLLM','HIGH','LOW','LOW','MEDIUM'), (57,'HLLH','HIGH','LOW','LOW','HIGH'), (58,'HLML','HIGH','LOW','MEDIUM','LOW'), (59,'HLMM','HIGH','LOW','MEDIUM','MEDIUM'), (60,'HLMH','HIGH','LOW','MEDIUM','HIGH'), (61,'HLHL','HIGH','LOW','HIGH','LOW'), (62,'HLHM','HIGH','LOW','HIGH','MEDIUM'), (63,'HLHH','HIGH','LOW','HIGH','HIGH'), (64,'HMLL','HIGH','MEDIUM','LOW','LOW'), (65,'HMLM','HIGH','MEDIUM','LOW','MEDIUM'), (66,'HMLH','HIGH','MEDIUM','LOW','HIGH'), (67,'HMML','HIGH','MEDIUM','MEDIUM','LOW'), (68,'HMMM','HIGH','MEDIUM','MEDIUM','MEDIUM'), (69,'HMMH','HIGH','MEDIUM','MEDIUM','HIGH'), (70,'HMHL','HIGH','MEDIUM','HIGH','LOW'), (71,'HMHM','HIGH','MEDIUM','HIGH','MEDIUM'), (72,'HMHH','HIGH','MEDIUM','HIGH','HIGH'), (73,'HHLL','HIGH','HIGH','LOW','LOW'), (74,'HHLM','HIGH','HIGH','LOW','MEDIUM'), (75,'HHLH','HIGH','HIGH','LOW','HIGH'), (76,'HHML','HIGH','HIGH','MEDIUM','LOW'), (77,'HHMM','HIGH','HIGH','MEDIUM','MEDIUM'), (78,'HHMH','HIGH','HIGH','MEDIUM','HIGH'), (79,'HHHL','HIGH','HIGH','HIGH','LOW'), (80,'HHHM','HIGH','HIGH','HIGH','MEDIUM'), (81,'HHHH','HIGH','HIGH','HIGH','HIGH') CREATE TABLE spat_idx_test_result( [perm_id] [int] NOT NULL, [num_cells] [int] NOT NULL, [permut] [nvarchar](4) NOT NULL, [g1t1] [bigint] NULL, [g1t2] [bigint] NULL, [g1t3] [bigint] NULL, [g1t4] [bigint] NULL, [g2t1] [bigint] NULL, [g2t2] [bigint] NULL, [g2t3] [bigint] NULL, [g2t4] [bigint] NULL, [PF_EFF][float] NULL, [IF_EFF][float] NULL, [GRIDL1] [int] NULL, [GRIDL2] [int] NULL, [GRIDL3] [int] NULL, [GRIDL4] [int] NULL, [TPIR] [bigint] NULL, [TPIP] [bigint] NULL, [ANOIRPBR] [bigint] NULL, [TNOOCILFQ] [bigint] NULL, [TNOOCIL3FQ] [bigint] NULL, [TNOOCIL4FQ] [bigint] NULL, [TNOOCIL0II] [bigint] NULL, [TNOOCIL4II] [bigint] NULL, [TNOIOIL3FQ] [bigint] NULL, [TNOIOIL4FQ] [bigint] NULL, [ITTCNTLGP] [float] NULL, [INTTTCNTLGP] [float] NULL, [BTTCNTLGP] [float] NULL, [ACPONTLGP] [float] NULL, [AOPG] [float] NULL, [NORSBPF] [bigint] NULL, [NORSBIF] [bigint] NULL, [NOTSFIC] [bigint] NULL, [NORO] [bigint] NULL, [PORNBPF] [float] NULL, [POPFRSBIF] [float] NULL ) INSERT INTO dbo.spat_idx_test_result VALUES (0,16,0,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL) END /* delete all rows from "spat_idx_test_result" table. This makes it ready to stuff in new results. !!!WARNING!!! if your test was interupted, the table will be cleared out and the test will begin from the beginning. You could try to modify this to start where you left off but I didn't have time and this worked well enough for me. */ DELETE FROM spat_idx_test_result WHERE perm_id != 0 /* set up counters */ DECLARE @a1 INT DECLARE @a2 INT DECLARE @a3 INT DECLARE @a4 INT /* set up variables to hold high/medium/low values and permutation to use in rebuilding the spatial index and recording stats */ DECLARE @lev1 VARCHAR(6) DECLARE @lev2 VARCHAR(6) DECLARE @lev3 VARCHAR(6) DECLARE @lev4 VARCHAR(6) DECLARE @permut VARCHAR(6) DECLARE @num_cell VARCHAR(4) DECLARE @time_str VARCHAR(20) DECLARE @perm_id VARCHAR(20) DECLARE @x xml DECLARE @pf_eff FLOAT /* create variables to hold timestamps for beginning and ending of test queries */ DECLARE @start_t DATETIME DECLARE @end_t DATETIME DECLARE @elapse_t INT /* begin looping through cell option permutations */ SET @a1 = @min_cells_per_obj WHILE @a1 <= @max_cells_per_obj BEGIN SET @a2 = 1 PRINT 'Started Testing for ' +CAST(@a1 AS VARCHAR(10)) +' cells per object' WHILE @a2 < 82 BEGIN SELECT @lev1 = level1, @lev2 = level2, @lev3 = level3, @lev4 = level4 FROM cell_opt_perm WHERE perm_id = @a2 SET @permut = '''' +(SELECT permutation FROM cell_opt_perm WHERE perm_id = @a2) +'''' EXEC (' CREATE SPATIAL INDEX ' +@idxnm +' ON ' +@tabnm +' ( [SHAPE] ) USING GEOGRAPHY_GRID WITH ( --!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! --MAKE SURE YOU EDIT THE BOUNDING BOX TO BE EXACTLY EQUAL TO THE BOUNDING --BOX OF YOUR SPATIAL TABLE --!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! GRIDS =(LEVEL_1 = ' +@lev1 +' ,LEVEL_2 = ' +@lev2 +' ,LEVEL_3 = ' +@lev3 +' ,LEVEL_4 = ' +@lev4 +' ), CELLS_PER_OBJECT = ' +@a1 +' , PAD_INDEX = OFF, SORT_IN_TEMPDB = OFF, DROP_EXISTING = ON, ALLOW_ROW_LOCKS = ON, ALLOW_PAGE_LOCKS = ON, FILLFACTOR = 100 ) ON [PRIMARY] ' ) PRINT 'Re-built index to ' +@permut SET @a3 = 1 SET @a4 = 1 WHILE @a3 < 5 BEGIN SET @start_t = GETDATE() EXEC ( 'CREATE TABLE #tmp_tab (shp GEOGRAPHY) DECLARE @g1 GEOGRAPHY SET @g1 = ' +@testgeom1 +' INSERT #tmp_tab (shp) SELECT r.Shape AS shp FROM ' +@tabnm +' r WHERE r.SHAPE.STIntersects(@g1) = 1 DROP TABLE #tmp_tab' ) SET @end_t = GETDATE() SET @elapse_t = (SELECT DATEDIFF(MS, @start_t, @end_t)) SET @num_cell = CAST(@a1 AS VARCHAR(6)) SET @time_str = CAST(@elapse_t AS VARCHAR(20)) IF @a3 = 1 BEGIN IF (SELECT TOP 1 perm_id FROM spat_idx_test_result) IS NULL BEGIN SET @perm_id = 1 END ELSE BEGIN SET @perm_id = CAST((SELECT MAX(perm_id+1) FROM spat_idx_test_result) AS VARCHAR(20)) END EXEC ( ' INSERT INTO spat_idx_test_result (perm_id, num_cells, permut, g1t' +@a3 +') VALUES (' +@perm_id +', ' +@num_cell +', ' +@permut +', ' +@time_str +')' ) END ELSE EXEC ( ' UPDATE spat_idx_test_result SET num_cells = ' +@num_cell +', permut = ' +@permut +', g1t' +@a3 +' = ' +@time_str +' WHERE perm_id = ' +@perm_id ) SET @a3 = @a3 + 1 END WHILE @a4 < 5 BEGIN SET @start_t = GETDATE() EXEC ( 'CREATE TABLE #tmp_tab (shp GEOGRAPHY) DECLARE @g2 GEOGRAPHY SET @g2 = ' +@testgeom2 +' INSERT #tmp_tab (shp) SELECT r.Shape AS shp FROM ' +@tabnm +' r WHERE r.SHAPE.STIntersects(@g2) = 1 DROP TABLE #tmp_tab' ) SET @end_t = GETDATE() SET @elapse_t = (SELECT DATEDIFF(MS, @start_t, @end_t)) SET @num_cell = CAST(@a1 AS VARCHAR(6)) SET @time_str = CAST(@elapse_t AS VARCHAR(20)) EXEC ( ' DECLARE @geom geography DECLARE @x xml DECLARE @PFVALUE float DECLARE @IFVALUE float DECLARE @GRIDL1VALUE int DECLARE @GRIDL2VALUE int DECLARE @GRIDL3VALUE int DECLARE @GRIDL4VALUE int DECLARE @TPIRVALUE bigint DECLARE @TPIPVALUE bigint DECLARE @ANOIRPBRVALUE bigint DECLARE @TNOOCILFQVALUE bigint DECLARE @TNOOCIL0IIVALUE bigint DECLARE @TNOOCIL4IIVALUE bigint DECLARE @TNOOCIL3FQVALUE bigint DECLARE @TNOOCIL4FQVALUE bigint DECLARE @TNOIOIL3FQVALUE bigint DECLARE @TNOIOIL4FQVALUE bigint DECLARE @ITTCNTLGPVALUE float DECLARE @INTTTCNTLGPVALUE float DECLARE @BTTCNTLGPVALUE float DECLARE @ACPONTLGPVALUE float DECLARE @AOPGVALUE float DECLARE @NORSBPFVALUE bigint DECLARE @NORSBIFVALUE bigint DECLARE @NOTSFICVALUE bigint DECLARE @NOROVALUE bigint DECLARE @PORNBPFVALUE float DECLARE @POPFRSBIFVALUE float --!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! --MAKE SURE YOU EDIT GEOGRAPHY VARIABLE BELOW TO REPRESENT A POLYGON --THAT IS WITHIN YOUR BOUNDING BOX --!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! SET @geom = geography::STPolyFromText(''POLYGON ((-83.883490 35.440092, -83.896426 35.715280, -83.121432 35.787017, -83.124960 35.510653, -83.883490 35.440092))'', 4269) --!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! --MAKE SURE YOU SPECIFY THE NAME OF YOUR SPATIAL TABLE --AND THE NAME OF THE SPATIAL INDEX -- IN THE sp_help_spatial_geography_index_xml VARIABLES --!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! exec sp_help_spatial_geography_index_xml GRSM_TRAILS , GRSM_TRAILS_IDX , 1, @geom, @x output SET @PFVALUE = @x.value(''(/Primary_Filter_Efficiency/text())[1]'', ''float'') SET @IFVALUE = @x.value(''(/Internal_Filter_Efficiency/text())[1]'', ''float'') SET @GRIDL1VALUE = @x.value(''(/Grid_Size_Level_1/text())[1]'', ''int'') SET @GRIDL2VALUE = @x.value(''(/Grid_Size_Level_2/text())[1]'', ''int'') SET @GRIDL3VALUE = @x.value(''(/Grid_Size_Level_3/text())[1]'', ''int'') SET @GRIDL4VALUE = @x.value(''(/Grid_Size_Level_4/text())[1]'', ''int'') SET @TPIRVALUE = @x.value(''(/Total_Primary_Index_Rows/text())[1]'', ''bigint'') SET @TPIPVALUE = @x.value(''(/Total_Primary_Index_Pages/text())[1]'', ''bigint'') SET @ANOIRPBRVALUE = @x.value(''(/Average_Number_Of_Index_Rows_Per_Base_Row/text())[1]'', ''bigint'') SET @TNOOCILFQVALUE = @x.value(''(/Total_Number_Of_ObjectCells_In_Level0_For_QuerySample/text())[1]'', ''bigint'') SET @TNOOCIL0IIVALUE = @x.value(''(/Total_Number_Of_ObjectCells_In_Level0_In_Index/text())[1]'', ''bigint'') SET @TNOOCIL4IIVALUE = @x.value(''(/Total_Number_Of_ObjectCells_In_Level4_In_Index/text())[1]'', ''bigint'') SET @TNOOCIL3FQVALUE = @x.value(''(/Total_Number_Of_ObjectCells_In_Level3_For_QuerySample/text())[1]'', ''bigint'') SET @TNOOCIL4FQVALUE = @x.value(''(/Total_Number_Of_ObjectCells_In_Level4_For_QuerySample/text())[1]'', ''bigint'') SET @TNOIOIL3FQVALUE = @x.value(''(/Total_Number_Of_Interior_ObjectCells_In_Level3_For_QuerySample/text())[1]'', ''bigint'') SET @TNOIOIL4FQVALUE = @x.value(''(/Total_Number_Of_Interior_ObjectCells_In_Level4_For_QuerySample/text())[1]'', ''bigint'') SET @ITTCNTLGPVALUE = @x.value(''(/Interior_To_Total_Cells_Normalized_To_Leaf_Grid_Percentage/text())[1]'', ''float'') SET @INTTTCNTLGPVALUE = @x.value(''(/Intersecting_To_Total_Cells_Normalized_To_Leaf_Grid_Percentage/text())[1]'', ''float'') SET @BTTCNTLGPVALUE = @x.value(''(/Border_To_Total_Cells_Normalized_To_Leaf_Grid_Percentage/text())[1]'', ''float'') SET @ACPONTLGPVALUE = @x.value(''(/Average_Cells_Per_Object_Normalized_To_Leaf_Grid/text())[1]'', ''float'') SET @AOPGVALUE = @x.value(''(/Average_Objects_PerLeaf_GridCell/text())[1]'', ''float'') SET @NORSBPFVALUE = @x.value(''(/Number_Of_Rows_Selected_By_Primary_Filter/text())[1]'', ''bigint'') SET @NORSBIFVALUE = @x.value(''(/Number_Of_Rows_Selected_By_Internal_Filter/text())[1]'', ''bigint'') SET @NOTSFICVALUE = @x.value(''(/Number_Of_Times_Secondary_Filter_Is_Called/text())[1]'', ''bigint'') SET @NOROVALUE = @x.value(''(/Number_Of_Rows_Output/text())[1]'', ''bigint'') SET @PORNBPFVALUE = @x.value(''(/Percentage_Of_Rows_NotSelected_By_Primary_Filter/text())[1]'', ''float'') SET @POPFRSBIFVALUE = @x.value(''(/Percentage_Of_Primary_Filter_Rows_Selected_By_Internal_Filter/text())[1]'', ''float'') UPDATE spat_idx_test_result SET num_cells = ' +@num_cell +', permut = ' +@permut +', g2t' +@a4 +' = ' +@time_str +', PF_EFF = @PFVALUE, IF_EFF = @IFVALUE, GRIDL1 = @GRIDL1VALUE, GRIDL2 = @GRIDL2VALUE, GRIDL3 = @GRIDL3VALUE, GRIDL4 = @GRIDL4VALUE, TPIR = @TPIRVALUE, TPIP = @TPIPVALUE, ANOIRPBR = @ANOIRPBRVALUE, TNOOCILFQ = @TNOOCILFQVALUE, TNOOCIL0II = @TNOOCIL0IIVALUE, TNOOCIL4II = @TNOOCIL4IIVALUE, TNOOCIL3FQ = @TNOOCIL3FQVALUE, TNOOCIL4FQ = @TNOOCIL4FQVALUE, TNOIOIL3FQ = @TNOIOIL3FQVALUE, TNOIOIL4FQ = @TNOIOIL4FQVALUE, ITTCNTLGP = @ITTCNTLGPVALUE, INTTTCNTLGP = @INTTTCNTLGPVALUE, BTTCNTLGP = @BTTCNTLGPVALUE, ACPONTLGP = @ACPONTLGPVALUE, AOPG = @AOPGVALUE, NORSBPF = @NORSBPFVALUE, NORSBIF = @NORSBIFVALUE, NOTSFIC = @NOTSFICVALUE, NORO = @NOROVALUE, PORNBPF = @PORNBPFVALUE, POPFRSBIF = @POPFRSBIFVALUE WHERE perm_id = ' +@perm_id ) SET @a4 = @a4 + 1 END SET @a2 = @a2 + 1 END SET @a1 = @a1 + 1 END PRINT 'Testing of ' +@tabnm +' spatial index: ' +@idxnm +' is complete!' GO
And execute like so:
DECLARE @BOUNDING VARCHAR(MAX)
SET @BOUNDING = 'geography::STPolyFromText(''POLYGON ((-83.883490 35.440092, -83.896426 35.715280, -83.121432 35.787017, -83.124960 35.510653, -83.883490 35.440092))'', 4269)'
DECLARE @QUERY VARCHAR(MAX)
SET @QUERY = 'geography::STPolyFromText(''POLYGON ((-83.883490 35.440092, -83.896426 35.715280, -83.121432 35.787017, -83.124960 35.510653, -83.883490 35.440092))'', 4269)'
EXEC sp_tune_spatial_index 'GRSM_TRAILS', 'GRSM_TRAILS_IDX', 4096, 4096, @BOUNDING, @QUERY
GO
