Load to temp FGDB or directly to Production Enterprise DB
1010
11-23-2020 01:53 PM
SSMIC3038
Curious if there are any opinions or experiences on wether a comprehensive ArcFM geometric network DB should migrate directly into the production Enterprise DB, or if a middle file geodatabase is perhaps a better route. Work everything out in the FGDB and then a streamlined load from FGDB to Enterprise DB? (in theory).
Once the FGDB is finished, export the schema to asset pkg to Enterprise DB (because the load process likely generated some model changes) and the workbooks *should* be able to be pointed to that new Enterprise DB.
AlixVezina
Hi Craig,
We would recommend as you've mentioned, the approach to start prototyping with a File Geodatabase until you are satisfied with the data load results in your prototype.
