Append Annotation feature class from source to target using Data Loading tools
1227
03-21-2024 05:16 AM
SumitMishra_016
When I am loading Annotation feature class from source to target, it is not loading correctly. Can I use "Load Data Using Workspace" for loading Annotation feature class from source to target?   @Robert_LeClair @PatrickGCowan    @TedHoward2  @AlixVezina
Robert_LeClair
Esri Esteemed Contributor
What GP tool are you using?  There is an Append Annotation Feature Class GP tool that you may wish to investigate.
PatrickGCowan
Annotation feature classes are supported in Data Loading Tools. I would suggest reviewing the below help, as there are some nuances with annotation such as certain fields are required, and older versions of annotation should be upgraded.
Annotation - ArcGIS Pro
Robert_LeClair
