CrowdSource Reporter: How to use USERID and NUMVOTES?
890
11-02-2017 01:12 AM
SamantaKruse
I'm new to Crowdsource reporter and I want to use USERID and NUMVOTES. I did work with the CrowdSource Reporter documentation, but I can't get the answers to my questions there.
I created a table including USERID and NUMVOTES but in use the participant is able to edit the USERID and NUMVOTES. (See the attached image: you can see that the participant is able to write a number for likes, which I assume that's not the way it should be 😉 )
So here are my questions:
- How to prepare the data/fields in ArcMap?
- Is the userID only saved if the participants of the survey are logged in or does guests get a random userid?
- Will the userID be saved if someone "likes" or "comments" on already left opinions?
I hope it's ok with follow-up questions a little bit later.
