UTM for Texas
18987
7
10-13-2016 07:00 AM
LanoYado
Because I am not GIS expert, so may be my question a quite basic question in GIS. I am working on Texas area (The whole state) but when I want to use TIN it says it's recommended to use projected coordinate. When I come to find the block or unit of the area using UTM, I found there are three blocks cover the whole state (13, 14, and 15). My question is, which one should I choose to cover the whole state?
Thanks in advance
MicahBabinski
Hi Lano,
That depends on what you will do with the data. The choice you make should be based in what characteristics you want to preserve and which you are ok with distorting between shape, area, distance, and direction. Texas is a big state - three UTM Zones and five state plane zones. You might want to see if the state of Texas provides any data to the public in a projected coordinate system and go with that.
Good luck.
LanoYado
Thanks Micah. I will google if the state provides any data in UTM.
ChrisDonohue__GISP
To build on what Micah Babinski stated, since Texas has multiple UTM zones, picking one UTM standard zone to try to use for the whole state won't work that well.  Instead, you want a projected coordinate system that covers the whole state.
That said, there are likely several available and it will not be obvious at first which one to choose.  Essentially all coordinate systems are a trade off between 4 factors:  shape, area, distance, and direction.  There is no coordinate system that preserves all 4; instead, each coordinate system is set up to preserve some of the factors at the expense of others.  So you will want to choose a coordinate system that matches the goals of your project.
For example, if the goal is to have polygons with the correct area but are not so worried about their shape getting distorted somewhat, an Equal-Area coordinate system would be a good choice.  However, Equal-Area would not be a good choice if the goal is to show the true distance of lines.
Choosing the Right Map Projection - Learning - Source: An OpenNews project
Chris Donohue, GISP
LanoYado
Thanks Chris, clear reason and good information.
ChrisDonohue__GISP
I should also add that for many GIS people (myself included) the subject of projections and coordinate systems is not something that comes easily at first.  So if it seems mystifying, read up on it and then ask questions here on GeoNet.  There are many knowledgeable people here who can help.  And for the total puzzlers, here on GeoNet we are often blessed with the expertise of MKennedy-esristaff (ESRI coordinate systems expert).
Chris Donohue, GISP
LanoYado
Thanks Chris, many times, when I ask question here in GeoNet, it shortens the time to me and gives me a right course to read about. I greatly appreciate the helps I got form all here in GeoNet.
DanPatterson_Retired
I am sure Melita Kennedy‌ would endorse people becoming familiar with a well know repository of coordinate systems and projections.  One can't go wrong with one with the name Texas in it
 NAD83 / Texas State Mapping System: EPSG Projection -- Spatial Reference
or a lambert conformal conic with a Texas flavor
 NAD83 / Texas Centric Lambert Conformal: EPSG Projection -- Spatial Reference
But I am sure there are others there as well... like these
Spatial Reference List -- Spatial Reference
From the help topics
What are map projections?—Help | ArcGIS for Desktop
and from that link
http://desktop.arcgis.com/en/arcmap/latest/map/projections/pdf/projected_coordinate_systems.pdf
