Transformation from GRS_1980 to OGSB_1936
11706
25
05-04-2016 05:21 AM
MS10
Hi, I'm attempting a transformation between these two coordinate systems. I've tried by adding the GRS_1980 raster then selecting Transformations > Using, however the only option is <custom> New Geographic Transformation. I used this method then tried to clip the GRS_1980 raster to the OGSB_1936 however I dont think it has worked correctly as the GRS raster doesnt align and overlay properly with the OGSB raster. Anyone have any advice, some details on the datasets below.
GRS_1980:
Spatial coverage: Europe
Pixel size: 500m
OGSB_1936:
Digital Elevation Model of area in southern England
Pixel size:50
MS10
OSGB data is here:
I've already succesfully used the OSGB to ETRS_1989 transformation on this data:Untitled_2.jpg
MS10
Note: I have been clipping (Data Management > Clip) the GRS_1980 data to the OSGB data prior to attempting any transfomations.
NeilAyres
And what are the details of your clip polygon?
See that error there - about empty geometry.
I think that the underlying raster and your clip geometry are not in the same coordinate system.
MS10
Clip raster is here:
NeilAyres
Then I still think you have messed up the coordinate system of the Lambert data.
I think it should look like this :
Note, this is the same parameters as your original, but the GCS is specified as WGS84
MelitaKennedy
Esri Notable Contributor
I agree with Neil. On your step when you change the coordinate system, rather than selecting the geographic coordinate system folder, right click the name of the current coordinate system, GRS_1980_IUGG_1980_Lambert_Azimuthal_Equal_Area, and select modify. That will open the dialog that I showed earlier. On that dialog, click the geographic coordinate system button on the lower right side. That will leave the Lambert azimuthal projection and parameters alone.
