Spatial domain: Why are Min X and Min Y negative?
3298
06-17-2016 09:26 AM
ElizabethMiller
Can someone explain why I see negative values in the spatial domain of a feature class? Min X and Min Y are negatives while Max X and Max Y are positive. The feature class is stored in Oracle and I am trying to troubleshoot the cause of some flakey spatial behavior. Feature Extent looks good but these negative values in the domain have me concerned. Is it possible they could be valid or is this a sign that something is definitely wrong? What is best way to correct them? Thanks for any thoughts.
AdrianWelsh
MVP Honored Contributor
Hi Elizabeth,
Try running the Repair Geometry tool on your features.
Repair Geometry—Help | ArcGIS for Desktop
ElizabethMiller
Hi Adrian -- thanks for the idea. The repair tool doesn't work on data stored in an oracle database, however I did do a test with this tool on a copy of the data exported to a file geodatabase. There were no problems detected with the data.
AdrianWelsh
So when you exported the data to a file gdb you did not see the negative numbers?
Tagging GeodatabaseMapping and Charting Enterprise DatabasesEnterprise GIS
DanPatterson_Retired
