Google coordinates to UTM coordinates in Dubai
7270
09-13-2024 12:07 AM
Fahad_Insprit
Hii...
can anyone help me to convert the google map coordinates to UTM coordinates that are used in Civil drawings in  Dubai. I tried to convert but its not working. Please suggest how to do that.
Thanks in advance
MelitaKennedy
Esri Notable Contributor
@Fahad_Insprit wrote:
Hii...
Thanks in advance
Can you give examples of:
  • input Google coordinate values
  • output UTM coordinates that you're getting (and what definition/parameters you are using)
  • what are the expected values
Based on what Cliff Mugnier wrote in his column on the United Arab Emirates, Dubai is not using a standard UTM zone but a local transverse Mercator zone so you would need to create a custom projected coordinate system.
The Dubai Local Transverse Mercator (DLTM) Grid is referenced to the WGS 84 ellipsoid, the Central Meridian λo = +55° 20’ E, and the False Easting = 500 km.  The Northings are presumably measured from the Equator.
MariahBlackhorse1
There are a number of converters online if you know your input system and what output system you want to convert to.
Here is one:
https://tagis.dep.wv.gov/convert/
