Everest 1830 to WGS 1984
16077
9
09-01-2015 04:44 AM
PradeepJoshi
Hello,
Please tell me how do I project a shapefile from Everest 1830 to WGS 1984? I can not find any transformation method for this.
Thank you.
JayantaPoddar
Hi Pradeep,
I am quoting a comment of Melita Kennedy​ from Coordinate transformation from WGS 1984 to Everest 1830 or vice versa?
We don't have any transformations for Everest 1830 because it's a ellipsoid (spheroid) and not a true geodetic datum/coordinate system. The data may be using Kalianpur 1937. Take a look at the geographic_transformations.pdf file located in your ArcGIS installation's Documentation folder for GCS that are used in India (or wherever the data is) and try some of them. It will mean redefining the Everest 1830 data with the Define Projection tool or the data's property page in ArcCatalog.
Melita
What happens if you reproject the data from Everest 1830 to WGS 1984 without using any transformation?
Project—Help | ArcGIS for Desktop
Think Location
PradeepJoshi
Thanks. But Melita's comment does not help me. The Kalianpur 1937 shows coordinates in negative meters and displays errors on invalid map extents while projecting to WGS 84.
If I do so it displays an error message saying Undefined geographic transformation.
JayantaPoddar
I could reproject a shapefile in Everest 1830 to GCS_WGS_1984 without any error. What is your exact source and target coordinate system?
Think Location
PradeepJoshi
I am trying to project a shapefile to GCS WGS 1984 that has following projection information.
PROJCS["M_UTM",GEOGCS["GCS_Everest_1830",DATUM["D_Everest_1830",SPHEROID["Everest_1830",6377299.36,300.8017]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Transverse_Mercator"],PARAMETER["False_Easting",500000.0],PARAMETER["False_Northing",0.0],PARAMETER["Central_Meridian",84.0],PARAMETER["Scale_Factor",0.9999],PARAMETER["Latitude_Of_Origin",0.0],UNIT["Meter",1.0]]
I think this is based on the Everest 1830 if not exact the same.
MelitaKennedy
Esri Notable Contributor
Hi Pradeep,
Because you said you were getting negative values after projecting the data, can you post the extents of the dataset?
We don't have a lot of information about transformations in India. There's one, Indian_1975_To_WGS_1984_1, that covers India and Nepal, but it's questionable. Survey of India just doesn't release that much information.
I would suggest modifying the data's coordinate system by replacing the geographic coordinate system with Indian 1975. You can do this through the data's property page in ArcCatalog. Next use the Project tool to create a new dataset in WGS84.
Melita
PradeepJoshi
Dear Melita,
I have attached the shapefile here. Would you please have a look?
JayantaPoddar
Pradeep,
I could successfully reproject the attached data to WGS_1984_Web_Mercator_Auxiliary_Sphere (No transformation method used). Let us know if you face any issue.
Think Location
PradeepJoshi
Thanks. It worked for me too. But I was trying to project to Geographic coordinate systems ==> World (not spheroid based) ===> WGS 1984.
I am not sure whether projecting to WGS_1984_Web_Mercator_Auxiliary_Sphere produces any error.
JayantaPoddar
Even reprojection to GCS_WGS_1984 is done successfully. And I don't see any mismatch between the two data.
Think Location
