Coordinate Systems Different Warning
2031
11-08-2019 01:58 PM
JoeBorgione
I just created a multi-role locator using the Create Locator tool in ArcGIS Pro 2.4.  For some odd reason, I'm getting the following warning:
 Input feature classes have different coordinate systems. Output locator will use coordinate system of the first one, 'AddressPoints': 'NAD_1983_StatePlane_Utah_Central_FIPS_4302_Feet'
All of the spatial data my agency has is NAD_1983_StatePlane_Utah_Central_FIPS_4302_Feet; when I look at both the meta data and the properties pane  of each they are all consistent. See attached images.
Does anyone see something I'm missing?
That should just about do it....
MelitaKennedy
Esri Notable Contributor
Hi Joe,
Is there anything different in the xy/z/m domain/tolerance/resolution values?
Melita
JoeBorgione
I'll check when i get back to work; celebrated Veterans Day today.
add 11/12/2019:
Melita- they all look the same to me.  See attached.
Melita Kennedy
MelitaKennedy
They look good to me. You might have to go to Tech Support and send the data, if possible, in for the locator team to debug.
JoeBorgione
Okay.  Thanks for looking into it for me!
