Coordinate system transformation given only differences as parameters
8245
11
04-08-2018 12:13 AM
RonMan
This is a question regarding coordinate system transformation of WGS84 or latlong to KosovoRef.  I am using ArcMap 10.3.1.
I am given the attached excel file given the parameter as differences (-2.37349693011492 and- 1415.26511242054).
I have done an excercise to test this in ArcGIS project tool using the  only kosovo coordinate system available but unfortunately i am getting a difference between the excel file and the transformed coordinates.
If given only parameter differences (-2.37349693011492 and- 1415.26511242054) can i input this in ArcMap to do the transformation for points and shapefiles?
My aim is to have ArcGIS transform/project as per the excel file.  How do i achieve this?
I hope someone could spare time to help me on this.
Regards,
Ron
UAE
RonMan
Thank you Melita for the information. I appreciate it very much.
By the way, I have watched a few of your presentation online about coordinate systems.
There are all very helpful.
Regards,
Ron
MelitaKennedy
Esri Notable Contributor
Thank you very much!
