ArcGIS coords don't match Google Earth
3053
04-27-2023 01:47 PM
Esther_Morrow
I am looking for a village in Indonesia.  The coordinates given are S 0 deg, 18'; E 130 deg, 40'.  On gEarth, it shows a village in that location.
In Pro 2.9, that position is in a different place and there is no village according to the imagery basemap.  Can anyone help me understand why the coordinates don't match?
Or better yet, what do I need to do to fix the problem?
Thanks!
BojanŠavrič
Hi @Esther_Morrow!
Your difference in location is caused by using degrees-minutes-seconds format as they would be decimal degrees.
0 deg 18' S is not -0.18 deg, but -0.3 deg; and
130 deg 40' E is not 130.40 deg, but 130.66666667 deg.
If I use correct decimal degrees in ArcGIS Pro, the point appears on the same location as on Google Earth.
I hope this helps!
BojanŠavrič
Hi @Esther_Morrow!
I hope this helps!
Esther_Morrow
Thank you so much!  I feel silly, but at least it was a simple solution.
