Mapping the Reconnection of Great Lakes Stream Networks
820
05-15-2025 03:17 PM
kyledankert37
With Trout Unlimited
By Kyle Dankert
In the Great Lakes region, the brook trout is Trout Unlimited’s mascot for a good reason. This vibrant salmonid is known as a native indicator species, as their ecology requires habitat parameters like river substrate, dissolved oxygen levels, cold water, healthy surrounding forests, and connected stream networks for survival and reproduction. If brook trout populations begin to dwindle, this is a sign that something unnatural is affecting the health of the entire system.
Although the Great Lakes are rich in hundreds of tiny stream networks, these networks are often blocked by road crossings throughout the region.
TU’s focus on reconnecting and restoring habitat for brook trout (Salvelinus fontinalus) also serves the needs of many Great Lakes riverine species..To follow along with the progress of our stream reconnection visit Great lakes TU’s Stream Reconnection Map from Experience Builder.
Field technician inspecting the markings on a brook trout caught in a Claybank Creek fish survey.Field technician inspecting the markings on a brook trout caught in a Claybank Creek fish survey.
These miles of reconnected habitat are restored through identification of barriers via data collection then the removal of these barriers at road and stream crossings, culverts, and other anthropogenic impacts to streams that inhibit aquatic organism passage.
GIS applications have become essential toward that mission.
Coldwater streams are defined by the Michigan Department of Natural Resources, as streams capable of remaining below 63.5 F year-round, even throughout the hot summer months. Cold water is an ecosystem service made possible by strong groundwater influence, forests, and a well-connected stream network.
TU collaborates with agencies and funding partners including US Forest Service, National Oceanic Atmospheric Administration, US Fish and Wildlife Service, National Fish and Wildlife , and more to reconnect hundreds of miles of upstream coldwater habitat to aquatic species like brook trout, restoring natural fluvial characteristics and providing climate resilience to freshwater resources.
Stream Reconnnect Map showing reconnected stream segments by year completed.Stream Reconnnect Map showing reconnected stream segments by year completed.  Map of similar area showing known stream barriers in the watershed.Map of similar area showing known stream barriers in the watershed.
This work is made possible through several ArcGIS field applications, especially data collection in Survey 123
Field technicians use Survey 123 to collect geomorphic data in order to determine if a stream location acts as a barrier for aquatic species at certain flows.
 Field Technicians surveying downstream and upstream geomorphology of a road / stream crossing site.Field Technicians surveying downstream and upstream geomorphology of a road / stream crossing site.
Field Maps has become an essential tool in recent years for both its offline capabilities and live tracking of progress. The effectiveness of restoration work is monitored through the uses of habitat and biological surveys, including macro-invertebrate surveys, stream temperature measurements, and electrofishing surveys focused on native brook trout populations. These data collection efforts are designed and executed through Field Maps for both office and field-based scenarios.
Commuting to work - Treks to survey sites are often executed by following directions through offline Field Maps apps.Commuting to work - Treks to survey sites are often executed by following directions through offline Field Maps apps. Field Crews on survey - Collection time and effort is also measured through field apps when a survey is commenced.Field Crews on survey - Collection time and effort is also measured through field apps when a survey is commenced. Measuring fish lengths and weights -Data is collected from biological samples like brook trout and then entered directly into Survey123 forums and saved.Measuring fish lengths and weights -Data is collected from biological samples like brook trout and then entered directly into Survey123 forums and saved.
During a day of field work in Northern Michigan, a TU aquatic resource technician will visit sites in the Huron-Manistee National Forest, working to conserve and restore trout populations by identifying barriers to aquatic organism passage.
These White Cedar and Hemlock forests are littered with treacherous two-track roads, where hauling survey gear through rugged hiking trails is often required.
Field Maps interface - Field Maps is used in all of our surveys for tracking completion of sites and getting directions offline.Field Maps interface - Field Maps is used in all of our surveys for tracking completion of sites and getting directions offline.
After hiking through the tamarack bush, the technician comes to a stream which they notice is cold to the touch, even on a hot summer’s day. This is due to the strong groundwater influence, and the shaded canopy from the thick forests particular to this region. However, this work site is impeded by a barrier, which not only blocks trout migration, but also effectively increases temperature of water downstream, causing further damage to the ecosystem and other species present like massive mayflies (Hexagenia limbata) and Mottled Sculpin (Cottus bairdii). Technicians utilize an offline compatible Field-Maps app developed from ESRI’s suite of field applications. The map identifies work sites for the day and links the associated survey defining the style of fieldwork needed.
The Aquatic Barrier Stream Crossing Survey is completed on a daily basis and identifies, for the technicians, potential barriers to a stream network. This survey requires many fluvial, erosion, and habitat measurements, including flow rate, stream bank-full width and structure width. A completed survey is then submitted on Survey 123 with an immediate barrier score response and sent to an online database to prioritize sites for restoration potential.
Bad Culvert - Barriers are often culverts that are perched (outlet above water level) or significantly impact the hydrology of a stream reach causing a barrier at most flows.Bad Culvert - Barriers are often culverts that are perched (outlet above water level) or significantly impact the hydrology of a stream reach causing a barrier at most flows.  Good Culvert - This restored crossing's design took into account the hydrology of this stream at many flow types and  rehabilitation of riparian and aquatic habitat.Good Culvert - This restored crossing's design took into account the hydrology of this stream at many flow types and rehabilitation of riparian and aquatic habitat.
Prioritization considers habitat reconnection potential, cost of reconstruction and landowner relationships, among other things. Once the future construction phase is completed, we can continue further up the stream network to find additional barriers to reconnect more habitat.
These restored sites are then monitored by TU staff through recurring biological surveys focusing on fish and macroinvertebrate communities, using field maps before and after the construction had taken place. With a completed project we can calculate the connected stream mileage to the next barrier updating our public stream reconnection map.
Bug Surveys - Survey 123 allows for effficient collection of Macro invertebrate survey data.Bug Surveys - Survey 123 allows for effficient collection of Macro invertebrate survey data.   Data collection - Field maps offers ease of data collection with the ability to update online layers on the fly. These layers and data are used for prioritization of restoration efforts and effectiveness monitoring of complted projectsData collection - Field maps offers ease of data collection with the ability to update online layers on the fly. These layers and data are used for prioritization of restoration efforts and effectiveness monitoring of complted projects
With these GIS applications, we will continue monitoring the progress of TU and our federal and private partners, as well as our local chapters and TU members.
By using and sharing these resources, we hope to continue to grow our engagement with more people who call these waters home, as well as others who collaborate, advocate, and hope for better stream health.
Ideally, maps like our stream reconnect resource help present an ethical and sustainable perspective for aquatic ecosystems and human transportation in the Great Lakes region.
Contributors
