How to create a video post
4814
6
09-23-2020 12:56 AM
Videos are hosted within a post content type with videos inserted in the post.
Videos must be MP4, YouTube or Vimeo, or another allowable URL source to be uploaded or embedded. The user must have permissions to upload a video within the group or space. Video size is unlimited. However, timeouts, loading issues, and lag may occur with large videos over 1GB depending on a user's internet, network, or browser.
Videos are a great way to share information, entertain, or to provide a simple how-to guide.
Remember to use videos from a reputable source that falls within the  Community Guiding Principles.
Please note the following about using videos:
  • Don't use video that does not come from a reputable source.
  • Do not use video to create a specific how-to instruction for using the community. If creating a community-specific how-to, please contact the Esri Community team at [email protected] to discuss your how-to needs and how we can help.
Create A Video Post
In your place or group, go to your Video board.
From your Video board, select Create A Post.
Enter the title of the video in the Subject Line.
Select the camera icon to upload a video, select a video from your gallery content, or insert a video from the web.
Select how you want the video size and alignment to display within the post if applicable.
Choose your Labels and enter applicable Tags.
If you do not want community members to add additional tags to your video, select the checkbox for Do not allow anyone to tag this article.
If you do not want community members to give a Kudos to your video, select the checkbox for Do not allow anyone to give kudos to this article.
If you are ready to publish the video to the community, Click Post.
From the published video post, click the Options menu. In the Options menu, you can make additional choices.
Select Edit Article to edit your video post.
Select Delete Article to delete the video post.
How to delete your video
Delete the video from your gallery
Go to your video gallery, and check the white checkbox on top of the video you want to delete.
Click the Options menu (stacked three dots) below the Upload a Video button. Select Delete All Checked Videos
You can also open the video from your video gallery page to play it or see the stats for the video before you delete it.  Click the video from your gallery to open the video.
To delete the video after you have opened it from the gallery, click the Options menu (stacked three dots) and select Delete Video.
If your video is in a post:
Go to the post where you embedded your video and remove the video embed. Update any references to the video in your post.
  • For example, if you stated in your post "See my video", edit or remove your reference, or rewrite your scenario to help explain your question or post topic. By doing this, you can help other Esri Community members follow the topic or problem you are trying to solve.
Comments
BrittanyBurson
Hi @Anonymous User, how do I delete a video after posting? I can't seem to find how to access "articles" as mentioned above to delete a video I uploaded. I can see it at https://community.esri.com/t5/video/gallerypage/user-login/{my user}
however I do not have any option to delete it. Also not sure how to access these easiest... I can't seem to find a way to the video gallery from my profile, for example.
Thanks!
by Anonymous User
Not applicable
Hi @BrittanyBurson, Just to clarify, are you trying to delete the post and the video or just the video?
It looks like you're referencing the video in this post: https://community.esri.com/t5/arcgis-experience-builder/filter-widget-results-lost-in-mobile-when-wi...
BrittanyBurson
Thanks @Anonymous User ! It's actually not that video, it's a "Hidden" one which I don't recall is actually attached to any post, which is why I can't seem to find how to delete it... thanks for your help, I feel really silly asking this!
by Anonymous User
Not applicable
@BrittanyBurson, No problem in asking at all! It's a new community, with new features - we're happy to look into it.  When you click the three dots under the Upload a Video button (from your first screenshot) do you see a menu dropdown? Does Delete All Checked Videos show up?
Or if you are still on the video screen (the second screenshot), do you see a stacked three dots option menu just above the "Classic StoryMaps mobile...Added by BrittanyBruson" text? That should also have the delete option in that stacked dots  (options) menu.
If you don't see it, let me know and I can look on our end.
BrittanyBurson
Yes.... Big facepalm on my end, thank you!
by Anonymous User
Not applicable
@BrittanyBurson, Glad I could help! I will update this document with these steps, so thanks for asking!
Version history
Last update:
‎05-19-2021 10:53 AM
Updated by:
Anonymous User
Contributors
