In addition to not being able to set a signature, I seem to be lacking some privilege related to posting photos.
I'd post a picture of what I mean, but, well.
It's attached to the post.
Solved! Go to Solution.
@jcarlson try now, there was an issue with your account and the correct permissions roles were not applied. you should now see the option to add an image. Please confirm. thank you.
@MichelleMathias a couple of complaints on this and I noticed that one of your docs is still undergoing a "virus scan" like the one below..
The "add_images.png" was added after... when I edited the original post. "Sad minion" was added when I initially created the post... seems add the image after might be the issue
this is "add_images.png" which is the attachment created in edit mode
If you use the Insert Photos when initially created, the photo/image works and doesn't resort to an attachment
@jcarlson Dan is correct, to embed/ add image into your post, you need to use the add photo option in the text editor.
We are investigating the virus scan issue, is cleared today and you can access the attachments loaded yesterday ( I think because our virus scan runs overnight, so I need to look into that and see how we can adjust it so it does not delay the opening of an attachments)
Thank you.
Thanks, Michelle!
