Tools & Tips: Blocking Users
605
12-04-2024 12:02 PM
JesseCloutier
Esri Community Manager
0 0 605
Esri Community’s Tools & Tips series provides a power-packed serving of “How-To” every month. These micro-sized guides make it easy to level up your platform knowledge and get more out of Esri Community.
The value: Members have control over which users are able to send them Direct Messages, mitigating unwanted communications while permitting those that are desired.
How to do it: There are two simple methods:
(1) Open your Direct Messages via the envelope icon in the topmost navigation, then open a message from the user you’re choosing to block. Finally, select the vertical ellipsis beside the trash bin icon and choose “Ignore User” from the available options.
(2) Open a user’s profile page by clicking on their username (can be found in a Member Search). Click the “Block User” button from the Contact Me widget on the right-hand side of the profile.
Process for blocking a user via your Esri Community inbox.
Keep in mind: Blocking a user prevents you from receiving Direct Messages they send to your account. They are not prevented from sending a message, nor do they receive a notification that they have been blocked or that their message will not be received.
Blocking a user does not prevent you from seeing messages they post in areas of Esri Community you have access to.
You can unblock a user by following steps in this Help Document: How to Block Users.
Contributors
About the Author
I'm a Community Manager focused on Engagement & Content here at Esri. My guiding ethos is that community — people coming together around shared purpose, demonstrating collective support, and collaborating in mutually beneficial ways — is the most powerful source for progress in the world. I'm at your service as we make great things happen through GIS.
