having trouble configuring new client so my db connections work
I have followed the instructions for installation and can connect from the command prompt using sqlplus, do i need to do something on the Arc side because none of my connection there work?
Did you check to see if this is a supported setup in 10.5.1?
I have been looking and there is very little mentioned about supported setups at all, where would I look?
Take a look at this link:
Oracle database requirements for ArcGIS 10.5.x—System Requirements | ArcGIS Desktop
You might need to install the patch that is mentioned in document
Thanks for the link, We got the client working by switching to the full version instead of the basic lite. I'll look into the patch,
