using oracle basic lite client 12.2 in windows 10 to connect arcgis 10.5.1 to oracle db
3269
05-21-2018 12:15 PM
AndrewShaw3
having trouble configuring new client so my db connections work
AndrewShaw3
I have followed the instructions for installation and can connect from the command prompt using sqlplus, do i need to do something on the Arc side because none of my connection there work?
MichaelVolz
Esteemed Contributor
Did you check to see if this is a supported setup in 10.5.1?
AndrewShaw3
I have been looking and there is very little mentioned about supported setups at all, where would I look?
MichaelVolz
Take a look at this link:
Oracle database requirements for ArcGIS 10.5.x—System Requirements | ArcGIS Desktop
You might need to install the patch that is mentioned in document
AndrewShaw3
Thanks for the link, We got the client working by switching to the full  version instead of the basic lite.  I'll look into the patch,
