Hi,I have installed the SSL cert and enabled https only access on the IIS 7.5 server. My rest services are working fine but then my report service is failing.In the logs I see that the reportservice url is still pointing to http://localhost/ArcGIS/BAServer/Services/HTMLextReportWebService/Service.asmx. This is expected to happen as i have not done any changes to BAServer after enabling https.Even after i changed the report service url to https://localhost/ArcGIS/BAServer/Services/HTMLextReportWebService/Service.asmx manually in BAServerConfig.xml i don't see any changes.After changing to https and restart the iis server, the logs have the following error
<Msg time='2011-05-03T11:47:59' type='DEBUG' code='0' target='[CReportingWSProxy::SetWebServiceProperties] from [.\ReportingWSProxy.cpp(722)]' machine='CDCRS729' process='5868' thread='5212'>Web-service property URL is: .https://localhost/ArcGIS/BAServer/Services/HTMLextReportWebService/Service.asmx</Msg>
<Msg time='2011-05-03T11:47:59' type='DEBUG' code='0' target='[CReportingWSProxy::SetWebServiceProperties] from [.\ReportingWSProxy.cpp(740)]' machine='CDCRS729' process='5868' thread='5212'>Exit WebServiceUtilities::SetWebServiceProperties method.</Msg>
<Msg time='2011-05-03T11:47:59' type='DEBUG' code='0' target='[CReportingWSProxy::Init] from [.\ReportingWSProxy.cpp(514)]' machine='CDCRS729' process='5868' thread='5212'>Execute GetVersion method to check web-service version.</Msg>
<Msg time='2011-05-03T11:47:59' type='DEBUG' code='0' target='[CReportingWSProxy::GetVersion] from [.\ReportingWSProxy.cpp(98)]' machine='CDCRS729' process='5868' thread='5212'>Enter CReportingWSProxy::GetVersion method.</Msg>
<Msg time='2011-05-03T11:47:59' type='ERROR' code='0' target='[CReportingWSProxy::GetVersion] from [.\ReportingWSProxy.cpp(105)]' machine='CDCRS729' process='5868' thread='5212'>Can't get version string from response message.</Msg>
<Msg time='2011-05-03T11:47:59' type='ERROR' code='0' target='[CReportingWSProxy::Init] from [.\ReportingWSProxy.cpp(517)]' machine='CDCRS729' process='5868' thread='5212'>Failed to check Web Service version.</Msg>
<Msg time='2011-05-03T11:47:59' type='ERROR' code='101040' target='[CASBReferencesHolder::GetReportingProxy] from [.\ASBReferencesHolder.cpp(227)]' machine='CDCRS729' process='5868' thread='5212'>Failed to init reporting service proxy. Probable cause - the service is not currently available or wrong reporting web service URL is specified.</Msg>
<DebugInfo>[HRESULT hr = E_FAIL]</DebugInfo>
I tried doing a Post Install but then i get a failure message when configuring the url for reporting service.What steps do i need to perform after the ssl cert is installed on the BA Server 10? Can someone point me to any documentation?Any help is greatly appreciated.
