Swipe app: limit zoom levels
947
05-29-2014 07:08 AM
CONABIONC_for_Knowledge_and_Us
Hi there,
Using the Swipe template I would like to limit the zoom levels.
Where do I have to add the "minZoom" & "maxZoom" command?
Thank you & kind regards,
Flo
Thank you Mark!
Adapting core.js under \src\app\storymaps\core\ of the dev-version worked perfectly.
saludos,
Flo
MarkCooney
Currently the swipe app does not offer a setting to limit zoom levels.  However, if you have some programming skills and are able to host the app yourself, you could add this functionality to your app by downloading the developers source code zip file from the github repo at:
https://github.com/Esri/swipe-map-storytelling-template-js
-Mark
Thank you Mark!
saludos,
Flo
