Summary storymap template
1130
04-11-2014 04:15 AM
DennisHunink
Hi There,
I'm experimenting some with the super cool Summary template. I deployed my data (see http://services2.arcgis.com/QAdJ8Cfk7wlxW3HM/ArcGIS/rest/services/ACLED_pointsonly/FeatureServer/0), which consists of almost 80.000 records. Every record is a conflict that occurred in Africa between 1997 en 2012. SO it makes sense to give a count and group the records, to see where concentrations are.
However, when I deploy the template, the count does not show the correct number. On a large scale it counts up to 3.000 cases, when zoomed-in it will go slightly higher (around 4.000).
What is going on here, how can I make the template show the right count?
See it live here: http://topografieindeklas.nl/playground/ACLED/summary/
GregoryL_Azou
The summary template is not produced by the Story Maps team, see the StoryMaps app list..
So you may have more chance to get answer in the ArcGIS Online forum.
DennisHunink
Just posted it on that forum as well. The template is on the default list when you create a web map and select 'make an application', and is on the GitHUB, so I figured it was e story map template.
