Strange behavior in IE
645
02-24-2014 08:51 AM
DavidStoddard
This is tested and repeatable in multiple versions of IE (9,10,11).
When I load a countdown map if the inital zoom and start location show data points the number icons for those data points will be lined up in the upper left hand corner of the map. Once I pan the map so the data points location is off screen that point snaps to it's proper location on the map and stays there even when I pull it back on screen. Any idea of whats causing this or how to remedy it?
