StoryMap Series (tabbed)
3367
8
10-30-2015 09:33 AM
JenniferMcRuer
Hi - I would like to use the Story Map Series (tabbed) to create my story of place: Five tabs, same map, but different themes.
Within each tab/associated map, I would like to add pushpins (or similar) so users can click to zoom into a location and see a particular thumbnail image (geotagged)/narrative block, etc. A sequential order is not important.
Is there a way to do this/a template to guide this kind of storymap?
Can geotagged photos be added to a Series StoryMap from Flicker, for example?
Is there an option for adding pushpins to tabbed maps to highlight particular locations?
Thank you!
KyleBalke__GISP
Jennifer
You may consider the Story Map Tour instead of the tabbed?  It supports all of the questions you mentioned (zoom, geotagged photos, Flickr).
Story Map Tour | Story Maps
If you wanted them all together you create five separate tours and then embed each in a tab in the Story Map Series.
Kyle
KyleBalke__GISP
Jennifer
Kyle
JenniferMcRuer
Thanks Kyle!
I have considered the tour, I was just trying to do what you have suggested...but in one step! - i.e., skip the embedding 😃  Do you know of any story map examples that have taken your approach? I'm trying to envision what the embedded series map would look like...
Jen
OwenGeo
Esri Notable Contributor
Hi Jennifer,
Here's a quick example I just worked up with a few embedded Map Tours so you can see what it will look like.
http://arcg.is/1XFgR88
Make sure to select the "stretch" option for positioning your content and don't include any description so the panel won't appear and obscure the map tour.
Owen
Owen Evans
OwenGeo
Also, if you want to remove the header for the embedded map tours you can just add &embed to the end of the URL like this.
http://esripm.maps.arcgis.com/apps/MapTour/index.html?appid=948a853492444b518993045cee0d0bad&webmap=...
I did this with the Presidential Birthplaces tour in the example posted above.
Owen
Owen Evans
MelissaMcGehee1
Funny, we were typing the same thing at the same time.
KyleBalke__GISP
Or you may consider the Shortlist template...unfortunately you currently have to host it yourself
Story Map Shortlist | Story Maps
OwenGeo
Shortlist should be available as a hosted app with a builder experience in the March 2016 release.
Owen Evans
MelissaMcGehee1
Also, when embedding, add "&embed" at the end of the URL for the Story Map to be embedded. Helps remove some of the extra content that you don't need and gives it a cleaner appearance.
