My first Story tour was a great success. When I tried to edit it, it failed. Since then I have remade it three times. Each time it fails.
All my points and images are gone. It loads an empty map.
Sorry about your issue but thanks for taking the time, that last Map Tour gave me a lead. The web map associated with the Tour is http://www.arcgis.com/home/webmap/viewer.html?webmap=a7d55448cfea47379cfbe93a2b287552
If you try to open the attribute table, you will get an error that let me think that when you created your tour you must have copy/pasted some text that ArcGIS Online don't like.
This can happen when you are copy/pasting content from the web or rich text editor like Word into the builder. One thing you could do is to copy/paste the text into a simple editor like notepad before copy/pasting into builder. By doing that you may or not notice some weird character in your text. Remove those if you see them.
Hope this helps
Good morning. You are correct, I was copying and pasting from Word. Especially since I did it so many times. I'll try just retyping it and see what happens. Later, tho. Must do some real work first. Thanks.
Judie Piner
Preservation & Technology
Yavapai-Apache Nation
Good morning, so far so good. I am up to six images and have saved and gone out twice. I think the Word copy/paste was the problem.
Judie Piner
