In reference to this thread that I started a while back:
https://community.esri.com/message/531732?et=watches.email.thread#531732
I have uploaded the latest version of Story Map Short list but still when I turn on my road layers is continues to crash my map. Turn them off again and the map is ok (see attached error message). As per the older referenced thread I used the latest template as of yesterday.
Also, cannot seem to change the logo from Esri to our own, here is the specific code I am changing (highlighted in attachment) any suggestions as to what I am doing wrong?
many thanks in advance!!
great thanks!! if I may ask you another question please, I am updating the map with new points, however my new points do not show up, looking at the table, is there something wrong with my X y points, I generated the X,y points with the toolbox tool and then added the lat long fields and 'calculated' by their corresponding X y filed. Can you see anything here that would explain why they are not showing up?
many many many thanks!
Lat / Longs need to be in decimal degrees.
John, could you start new threads for new issues? Makes it easier for us to track and also helps people search Geonet and find issues and questions they might have.
Will do, many thanks!!!!
Last week we also updated the Story Map Shortlist code with fixes to the original labeling issue that John reported. https://github.com/Esri/shortlist-storytelling-template-js/releases
See the latest release on that page (version 1.4.7).
