Story maps do not work in IE
5168
01-02-2015 01:06 PM
AmyWard
I have made a web app story map, and it works wonderfully in Firefox and chrome. However I can not get it to load in IE. Any suggestions on how to fix? I am currently running IE10 but others in my office can not look at it either in IE.
RupertEssinger
Esri Alum
Hi Amy, We need to know which story map application you are used to make your story map. There are several of them: Apps | Story Maps
Also assuming your story map is shared publicly and not only accessible inside your organization, could you post a link to it here so we can try it.
CraigCheeseman
This issue also occurs for me.  Both the direct app crashes in IE 10: http://tnc.maps.arcgis.com/apps/MapSeries/?appid=eced0b2ac74449d2b446f96d13fdd82e
It also crashes in my hosted version: http://www.nyanc-alt.org/gis/ausable-story-map/
Both work fine in Chrome, Firefox and Safari.  Our office required IE 10 for a few internal applications.  I do get the application to load in IE 11 but it does seem a bit glitchy.  It does not hold the zoom and location when going from one tab to the next.
SubodhDhakal
Hi Craig,
Both your link is working for me in IE 11.0.9600.17501. I had issue with my picture not displaying in IE but was perfectly working in Chrome. As pointed from ESRI, I had 3"///" forward slash on the link for picture in CSV which after changing works find. http://demos.interpret.co.nz/StoryMaps/InterpretTeam/
