Hi, is it any way to make pin smaller? I have so many points on the map, and it looks so busy. Thanks.
-Feng
Solved! Go to Solution.
Shortlist doesn't support changing the size of the pin markers in the Builder. The symbol can be changed if you customize the app by downloading/self-hosting the code.
Rupert
Rupert
Hi Rupert, I have downloaded the shortlist template, am I able to customize the pin size in the files in it? if yes, which file I should look at? Thank you.
