Hi!
I have problem with story map settings. I`im trying change logo in header (esri logo for my own). My .jpg has proper size an it hosted on Flickr/Picasa. When i`m pasting ulr photo nothing happened ;/ Have you got any ideas? Thanks a lot for yours help/
Solved! Go to Solution.
There is an issue in the dialog I have noticed and have submitted as a bug report: sometimes the URL you enter for a custom logo is ignored when you press Apply,
It always accepts the URL if you paste the URL in, then press Enter, then press Apply. Try that and I think it will work for you.
Which Story Map application template are you using? There are several of these ![]()
Hi, I am having the same problem using the Map Series builder. When I switch it to my logo URL and hit apply it just changes to the ESRI logo. Thanks.
Thanks, that worked.
