We recently finished a story map found here - http://tnc.maps.arcgis.com/apps/MapSeries/index.html?appid=d709594335ff48389171e2745a0b057c
It worked in the months prior to today but as soon as we set it to public, it returned "Story is initializing Thanks for waiting" while endlessly loading. We've tried several browsers, computers and no luck. Does anyone know why it is doing this? Any insight into what is happening would be helpful as I can't even edit it.
Solved! Go to Solution.
I am also running into this issue in ArcGIS Enterprise 10.8.1 with a Map Series Story map embedded into an iFrame. If I make the map public, it opens right up but if I share it to the organization, it does not finish opening and does not pop-up the authentication request.
Hello ESRI-Community,
today we did some changes within Story Map. Since these changes, its not possible to open the Story Map anymore.
Message: "Story is initializing Thanks for waiting" shows up and its not loading any content. It worked in the years prior. Was there any update?
Thanks!
